Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?
Nick MBC /
> Bob Blarney Wrote:
> Your comments have no relevance to the problem. The starter system
> works perfectly.
> The problem is in the electrical generation system. The important point
> is that the shop manual warns that rotating the crankshaft in the
> 'wrong' direction may somehow damage the generator - the ignition and
> the lighting and battery charging circuit components.
> I'm wondering if, during the installation of starter crankcase, that the
> generator flywheel was rotated in the clockwise direction, and so
> damaged the electrical system.
Are you trying to troll? Read what has been said again; the shop manual warns that not to protect the electrical system but to protect the starter mechanism. Wind that shit backward then go to start it and you'll see what he means cause your starter spring will break.
He's saying your electrical issue has nothing to do with the flywheel being rotated the wrong direction. From an electronics standpoint, that doesn't really make sense. Nothing has been damaged from magnets spinning the opposite rotation of normal operation (edited)
  spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Topic by: Bob Blarney Bob Blarney 08/20/19 10:21AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 11:56AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 01:25PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 01:39PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 02:44PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Nick MBC Nick MBC 08/20/19 03:30PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 04:53PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 05:10PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 04:19PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Jack Rutherford Jack Rutherford 08/20/19 05:08PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 06:13PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Aaron Blair Aaron Blair 08/21/19 04:52AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/21/19 07:41AM
