Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?
live ɘvil /
Do not turn motor backwards because of wind up starting mechanism. HAS NOTHING TO DO WITH ANY ELECTRIONICS.
If you do inadvertently turn it backwards then all that is needed is to pull rear brake lever to release spring.
What happens is that if its turned backwards it winds the clock spring some. Then when one goes to start motor by winding clock spring with pedal it gets over wound and breaks or fails
Try it and you will hear the ratchet paws on the starter side clicking as it winds up the starter spring. Just be sure to pull rear brake lever to release before you go to start motor. (edited)
  spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Topic by: Bob Blarney Bob Blarney 08/20/19 10:21AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 11:56AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 01:25PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 01:39PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 02:44PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Nick MBC Nick MBC 08/20/19 03:30PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 04:53PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 05:10PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 04:19PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Jack Rutherford Jack Rutherford 08/20/19 05:08PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 06:13PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Aaron Blair Aaron Blair 08/21/19 04:52AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/21/19 07:41AM
