Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50ii
ҎаЬlο Ŕivӗгa /
yep I was afraid I had a role in my DR's demise.
lesson learned & hard knock taken... =)
> live ɘvil Wrote:
> Chamfer the ports to prevent snagging a ring. Always
> check ring end gap.
  70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiTopic by: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/18/19 07:06PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Jack Rutherford Jack Rutherford 08/18/19 07:59PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: live ɘvil live ɘvil 08/18/19 08:00PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Jack Rutherford Jack Rutherford 08/18/19 08:30PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/19/19 01:31AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: live ɘvil live ɘvil 08/19/19 02:53AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/20/19 12:20AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Captain Janeway Captain Janeway 08/18/19 11:36PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/19/19 01:26AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/19/19 01:28AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Captain Janeway Captain Janeway 08/19/19 06:40PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/20/19 12:26AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/19/19 01:25AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Jack Rutherford Jack Rutherford 08/19/19 05:41PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/20/19 12:29AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/20/19 03:56AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/25/19 08:44PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: live ɘvil live ɘvil 08/25/19 09:11PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/26/19 03:01AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/26/19 01:17AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/19/19 11:27AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/20/19 12:23AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/26/19 01:25AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/26/19 03:17AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/26/19 03:32AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: live ɘvil live ɘvil 08/26/19 07:56AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/28/19 12:43AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/26/19 11:31AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/28/19 12:41AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/26/19 01:37AM
