Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50ii
ҎаЬlο Ŕivӗгa /
> Captain Janeway Wrote:
> > > I had this same kind of blowout on one of mine and that clip trashed
> > the
> > > cylinder. Wanted to kick myself. The kit only had about 500 miles on
> > it.
> > > I'm guessing the clip just didn't sit right and wiggled loose
> > It's a little disconcerting that those clips can pop-out so "easy". I
> > can only hope this only happens after serious overheating.
> I think this one I just didn't seat right. User error. I've been riding
> them for years and it's the only time it's ever happened. I've been told
> to use clips with no "ears" on them or at minimum only one. I think I
> got lazy on this one because that was all I had. The two-eared ones are
> too easy to bend and deform so they don't seat right. Also, the opening
> on the clip faces towards the bike, not away.
Yep, I thought I had been OCD-careful about making the clips seat right on the wrist pin when I installed but maybe still f-d up?.. Am thinking yes maybe the 1-ear clips (or 0-ear clips) may be the better choice going forward. Had no idea about the direction they face making a difference. Otherwise only way I can understand one popping out would be due to extreme heat / warping
  70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiTopic by: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/18/19 07:06PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Jack Rutherford Jack Rutherford 08/18/19 07:59PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: live ɘvil live ɘvil 08/18/19 08:00PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Jack Rutherford Jack Rutherford 08/18/19 08:30PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/19/19 01:31AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: live ɘvil live ɘvil 08/19/19 02:53AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/20/19 12:20AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Captain Janeway Captain Janeway 08/18/19 11:36PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/19/19 01:26AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/19/19 01:28AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Captain Janeway Captain Janeway 08/19/19 06:40PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/20/19 12:26AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/19/19 01:25AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Jack Rutherford Jack Rutherford 08/19/19 05:41PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/20/19 12:29AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/20/19 03:56AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/25/19 08:44PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: live ɘvil live ɘvil 08/25/19 09:11PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/26/19 03:01AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/26/19 01:17AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/19/19 11:27AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/20/19 12:23AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/26/19 01:25AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/26/19 03:17AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/26/19 03:32AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: live ɘvil live ɘvil 08/26/19 07:56AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/28/19 12:43AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/26/19 11:31AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/28/19 12:41AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/26/19 01:37AM
