Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50ii
ҎаЬlο Ŕivӗгa /
> Marc Friedman Wrote:
> The problem with hobbits is heat soaking. I've got three and each has a
> unique attempt to mitigate it.
> 1. 60 cc stocko shocko ...dos cycles motzig obtained jailing head
> ...major improvement. I used a Cheetachrome pull start because it's got
> a pa 50-1 crank so one way bearing won't work without major changes.
> 2. Athena 70 cc kit with derby head remachined and decomp sealed And
> studs slotted - one way bearing .
> 3. Mallosi watercooler kit with Bosch 12 v pump, radiator and onotjer
> one way bearing.
> Otherwise u r limited in how u ride your moped. If u keep a Hobbit stock
> it's designed not to seize because it produces less heat.
Marc,
Did you get the PUCHONDA sport touring 46mm head from Treatland to work? I am considering this head with the Wizard 70cc kit and 2mm spacers.... Sure would be nice if it cooled things down.
  70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiTopic by: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/18/19 07:06PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Jack Rutherford Jack Rutherford 08/18/19 07:59PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: live ɘvil live ɘvil 08/18/19 08:00PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Jack Rutherford Jack Rutherford 08/18/19 08:30PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/19/19 01:31AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: live ɘvil live ɘvil 08/19/19 02:53AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/20/19 12:20AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Captain Janeway Captain Janeway 08/18/19 11:36PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/19/19 01:26AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/19/19 01:28AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Captain Janeway Captain Janeway 08/19/19 06:40PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/20/19 12:26AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/19/19 01:25AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Jack Rutherford Jack Rutherford 08/19/19 05:41PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/20/19 12:29AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/20/19 03:56AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/25/19 08:44PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: live ɘvil live ɘvil 08/25/19 09:11PM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/26/19 03:01AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/26/19 01:17AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/19/19 11:27AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/20/19 12:23AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/26/19 01:25AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/26/19 03:17AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/26/19 03:32AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: live ɘvil live ɘvil 08/26/19 07:56AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/28/19 12:43AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/26/19 11:31AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: ҎаЬlο Ŕivӗгa ҎаЬlο Ŕivӗгa 08/28/19 12:41AM
  Re: 70cc 46mm DR Kit died - Is the Cylinder Toast? - Hobbit pa50iiRe: Marc Friedman Marc Friedman 08/26/19 01:37AM
