Re: Headlight, Brake Light and turn signals all just went out.
♣Slew Foot♣ /
If it's the points model take the blue black wire from the tail grounded the frame take the blue black where it goes from the Magneto and grounded the ignition block double check the coil afterwards to make sure it's still working it might be your coil failed to check it you can run voltage through it from a 9 volt and it should magnetized if it's good if it's bad it will heat up where the short is but you have to isolate the circuit to test.
