Re: Tomos A3 sputtering with throttle
♣Slew Foot♣ /
A condensers easy man you just go get a 399 gm1 or even a capacitor all it does is take the overcharge you put it in your circuit it will work but usually a failed condenser wouldn't make it sputter it would make it quit cool down and then I would work again sometimes if it's an old points model the blue wire that goes under the points gets pinched and will exhibit the same result it would sputter it could be the central post insulator on the points it could be a lot of things but the best thing to do is to start with the very simple as stupid as shit the kill switch make sure that shit ain't vibrating and giving you a are alternate kill
