Re: Batavus HS50 Needle Bearings? cleaning??
♣Slew Foot♣ /
I do believe those needle bearings that they're referring to are the ones inside of your pulley and your clutch for the most part don't stress about it run Marvel Mystery Oil once a month in your gas instead of normal 50 to 1 add 40 to 1 an ad 10 Marvel the clutch bearing is oiled bye a cup because the crankcase actually leaks on the clutch side to lubricate those needles so if you run Marvel once a month he'll keep them babies nice and clean I've never had a problem with the free Wheels
