Re: rusty Puch gas tank
live ɘvil /
> Seth B Wrote:
> > Jonathan Bennett Wrote:
> > Dish soap, cordless drill and a length of 3/8” galvanized steel cable.
> > I find it best to solder a couple places to prevent unraveling.
> > For the drill chuck end, brush about 3” with flux and solder like
> you’re
> > soldering a copper pipe. For the cleaning end, come up the cable about
> > 6” and brush a couple inches with flux and solder.
> > Once cooled, fray the cleaning end out. and start working it into the
> > bottom of the tank with some soap and water. Drain, rinse, repeat. I
> use
> > a pair of leather welding glove because a wire through hand would
> suck.
> > If it’s still giving you rust specs, get a steel wool, the coarse wire
> > type, not the fine stuff. Cut a chunk of it and thread it onto the
> > frayed end. Keep drilling. Forward and reverse. Pulling the cable
> > almost all the way in and out but be careful because it’ll want to
> coil
> > up on you.
> > It’s easier if you’ve got a bicycle stand so you can tilt the bike
> > forward. I removed the front tire so I could tip it all the way
> forward.
> > I then tip it forward and get a 1/2” or 3/4” hose and use it with a
> shop
> > vac to suck out as much as possible. I flush it with water and even
> the
> > blow nozzle on an air compressor in the petcock hole.
> > Then, after I’ve gotten it as clean as possible, I go through the
> > recommended evaporust soaking and such.
> > FYI, I spent 5 hours on my last Maxi. I’ve promised myself to not buy
> > rusty tanks if at all possible.
> > Good luck.
> > And don’t forget to run a fuel filter.
> Wow, talk about doing things the hard way. But whatever works for you.
+1^
Let the vinegar do the work.
I've let em soak for over a week before.
Dump, inspect and refill if necessary. When dumping vinegar out of tank drain back into original bottle in case you need to soak longer.
