Re: rusty Puch gas tank
Seth B /
> Jonathan Bennett Wrote:
> Dish soap, cordless drill and a length of 3/8” galvanized steel cable.
> I find it best to solder a couple places to prevent unraveling.
> For the drill chuck end, brush about 3” with flux and solder like you’re
> soldering a copper pipe. For the cleaning end, come up the cable about
> 6” and brush a couple inches with flux and solder.
> Once cooled, fray the cleaning end out. and start working it into the
> bottom of the tank with some soap and water. Drain, rinse, repeat. I use
> a pair of leather welding glove because a wire through hand would suck.
> If it’s still giving you rust specs, get a steel wool, the coarse wire
> type, not the fine stuff. Cut a chunk of it and thread it onto the
> frayed end. Keep drilling. Forward and reverse. Pulling the cable
> almost all the way in and out but be careful because it’ll want to coil
> up on you.
> It’s easier if you’ve got a bicycle stand so you can tilt the bike
> forward. I removed the front tire so I could tip it all the way forward.
> I then tip it forward and get a 1/2” or 3/4” hose and use it with a shop
> vac to suck out as much as possible. I flush it with water and even the
> blow nozzle on an air compressor in the petcock hole.
> Then, after I’ve gotten it as clean as possible, I go through the
> recommended evaporust soaking and such.
> FYI, I spent 5 hours on my last Maxi. I’ve promised myself to not buy
> rusty tanks if at all possible.
> Good luck.
> And don’t forget to run a fuel filter.
Wow, talk about doing things the hard way. But whatever works for you.
