Re: 1975 Puch Maxi rebuilt but has very low speed/acceleration issues
Seth B /
> Lee Snover Wrote:
> > Seth B Wrote:
> > Clean your exhaust. If you didn’t get the baffle out, you cleaned
> > nothing. If it’s stuck, it’s because it’s plugged up and locked in
> place
> > with oil/carbon build up. You must clean the baffle. That’s the part
> > that gets plugged up!
> So the baffle is all the stuff left in the main pipe after you take out
> the header and header pipe? It didn't look like that came out on mine.
> If that's the case, how do you break it free. I assumed it was welded
> in, and I ran about 4 cans of brake cleaner through at every angle I
> could manage. Got a lot of stuff out, but taking it apart would be
> optimal.
Yes, The baffle is in the tail section. There’s a nut in the center holding it in. Once the nut is removed, the baffle can come out, but they are often stuck. To get it unstuck, I heat the exhaust up with a torch and then spray the inside down with oven cleaner, and let it sit a few minutes. That has always worked for me.
