Re: 1975 Puch Maxi rebuilt but has very low speed/acceleration issues
Lee Snover /
> Seth B Wrote:
> Clean your exhaust. If you didn’t get the baffle out, you cleaned
> nothing. If it’s stuck, it’s because it’s plugged up and locked in place
> with oil/carbon build up. You must clean the baffle. That’s the part
> that gets plugged up!
So the baffle is all the stuff left in the main pipe after you take out the header and header pipe? It didn't look like that came out on mine. If that's the case, how do you break it free. I assumed it was welded in, and I ran about 4 cans of brake cleaner through at every angle I could manage. Got a lot of stuff out, but taking it apart would be optimal.
