what does it do, how, and where can i get one cheap
No such thing as cheap with these....
It's the transmission for the Hobbit. It uses the centrifugal force from the engine RPM's to change the gear ratio applied to the rear wheel. Do you just need a variator or the entire clutch assembly?
the clutch is there the belt is spinning on where the variator should be
I have an elite 150 im parting out that one won't fit, right?
also what physically happens to do this?
