Re: Vespa Euro Clutch Repair
DrGeorgeTompson (Alan) /
> Les B. Wrote:
> Dr George, is there a tool or method to compress the spring, when
> rebuilding?
A friend to hold it down or put the nut on helps but I've put stiffer springs on by myself when no ones around. Just put the clutch on a table or whatever and push the plates on over the spring and thread the nut on a turn or two so you can rest before sending it home. The swearing helps.
