Re: How do you adjust a dellorto carburetor?
Blukas Lukas /
The seat is sealing perfectly, it is probably just the jets, i think it was origionally clogged when i ran it for the first time in 20 years cause some of the residue that came from the rusted tank probably clogged part of it, the filter is a bit dirty, so i wouldnt be suprised that it was making it leaner, cause when i wanted to check what number it was, it was a bit clogged, but i cleared it up.
  How do you adjust a dellorto carburetor?Topic by: Blukas Lukas Blukas Lukas 08/08/19 01:59PM
  Re: How do you adjust a dellorto carburetor?Re: Stephen Simmons Stephen Simmons 08/08/19 04:36PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/08/19 05:01PM
  Re: How do you adjust a dellorto carburetor?Re: Don Ohio Don Ohio 08/08/19 10:26PM
  Re: How do you adjust a dellorto carburetor?Re: Rebel Moby Rebel Moby 08/08/19 06:25PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/08/19 06:46PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/08/19 06:56PM
  Re: How do you adjust a dellorto carburetor?Re: Stephen Simmons Stephen Simmons 08/08/19 08:25PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/08/19 09:34PM
  Re: How do you adjust a dellorto carburetor?Re: Stephen Simmons Stephen Simmons 08/08/19 09:55PM
  Re: How do you adjust a dellorto carburetor?Re: Seth B Seth B 08/09/19 01:04AM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/09/19 03:25AM
  Re: How do you adjust a dellorto carburetor?Re: pat splat pat splat 08/09/19 04:01AM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/09/19 03:42PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/09/19 04:19PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/09/19 04:39PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/09/19 05:43PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/09/19 06:50PM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/09/19 08:07PM
  Re: How do you adjust a dellorto carburetor?Re: Seth B Seth B 08/10/19 12:28AM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/10/19 12:32AM
  Re: How do you adjust a dellorto carburetor?Re: Stephen Simmons Stephen Simmons 08/09/19 08:34PM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/10/19 12:56AM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/10/19 01:06AM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/10/19 01:11AM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/10/19 11:23AM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/10/19 01:37PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/10/19 03:43PM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/10/19 04:04PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/10/19 04:41PM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/10/19 05:44PM
