Re: How do you adjust a dellorto carburetor?
live ɘvil /
> pat splat Wrote:
> your float needle isnt stopping fuel from entering carb, flooding
> engine. clean needle , needle seat n carb,
I was getting there.
When you are absolutely sure float is not flooding carb, proceed take to top speed and see of it 4 strokes. Increase main jet size until it four strokes on top end, then go back down one jet size.
Low end and idle will most likely be a little rich on a/f at this point. You will need to tune low end and idle with something other than original slide within carb. A complete selection of slides were once available for just this reason. Notice as they progress in design that they are letting in more air and or reducing lift of fuel from float bowl @ idle, lowend, midrange. Better learn yer slides.
BEHOLD
  How do you adjust a dellorto carburetor?Topic by: Blukas Lukas Blukas Lukas 08/08/19 01:59PM
  Re: How do you adjust a dellorto carburetor?Re: Stephen Simmons Stephen Simmons 08/08/19 04:36PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/08/19 05:01PM
  Re: How do you adjust a dellorto carburetor?Re: Don Ohio Don Ohio 08/08/19 10:26PM
  Re: How do you adjust a dellorto carburetor?Re: Rebel Moby Rebel Moby 08/08/19 06:25PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/08/19 06:46PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/08/19 06:56PM
  Re: How do you adjust a dellorto carburetor?Re: Stephen Simmons Stephen Simmons 08/08/19 08:25PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/08/19 09:34PM
  Re: How do you adjust a dellorto carburetor?Re: Stephen Simmons Stephen Simmons 08/08/19 09:55PM
  Re: How do you adjust a dellorto carburetor?Re: Seth B Seth B 08/09/19 01:04AM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/09/19 03:25AM
  Re: How do you adjust a dellorto carburetor?Re: pat splat pat splat 08/09/19 04:01AM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/09/19 03:42PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/09/19 04:19PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/09/19 04:39PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/09/19 05:43PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/09/19 06:50PM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/09/19 08:07PM
  Re: How do you adjust a dellorto carburetor?Re: Seth B Seth B 08/10/19 12:28AM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/10/19 12:32AM
  Re: How do you adjust a dellorto carburetor?Re: Stephen Simmons Stephen Simmons 08/09/19 08:34PM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/10/19 12:56AM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/10/19 01:06AM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/10/19 01:11AM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/10/19 11:23AM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/10/19 01:37PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/10/19 03:43PM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/10/19 04:04PM
  Re: How do you adjust a dellorto carburetor?Re: Blukas Lukas Blukas Lukas 08/10/19 04:41PM
  Re: How do you adjust a dellorto carburetor?Re: live ɘvil live ɘvil 08/10/19 05:44PM
