Re: DT50 Ignition help
P D /
> Mr Chubbins Wrote:
> So finally a follow up. Turned out the resistor on the spark plug was
> wonky. I took it off and threaded it back in and it started sparking
> again.
> Will probably change to a fresh coil once I figure out the carb again.
> Will start a new post on it.
> Thanks.
What ??? There is no resistor ON the spark plug .
There might be one in the plug cap . Maybe that's what you mean ?
