Re: DT50 Ignition help
Mr Chubbins /
So finally a follow up. Turned out the resistor on the spark plug was wonky. I took it off and threaded it back in and it started sparking again.
Will probably change to a fresh coil once I figure out the carb again. Will start a new post on it.
Thanks.
