Low compression pa50I
Jakob N /
I have a stock pa50I . I did a compression test and I got 25psi. So order a new piston,rings and gaskets. I put it back together with all the new stuff without the ring expander cause the piston wouldn't go into the cylinder with it on. I did another compression test and I'm getting 15psi. What could be the issue
