Re: Just joined the Moped Army - tons a first timer questions
Mike Boyd /
Might be a ZA50 based on the wheels and model number, hard to say with that picture and the aftermarket color scheme, could be either one. Post a pic of the other side of the bike or let us know if you're running a one speed or 2 speed motor.
I don't think your acceleration problems are due to your transmission fluid. That and your lack of idle once warmed up points to poor carb tuning or air leaks usually. You're leaving the choke OFF right? (pull tab is all the way up, not pressed in?) Have you adjusted your idle screw on the carb in at all? If you can get it to idle you can at least check for basic airleaks
  Just joined the Moped Army - tons a first timer questionsTopic by: Jordan Carter Jordan Carter 08/03/19 03:39PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Don Ohio Don Ohio 08/03/19 04:42PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Rebel Moby Rebel Moby 08/03/19 05:14PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/03/19 08:02PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Seth B Seth B 08/04/19 01:21AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Rebel Moby Rebel Moby 08/04/19 09:22AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Daniel '' Daniel '' 08/04/19 01:05PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Probably Fred Probably Fred 08/03/19 08:41PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/03/19 10:14PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/04/19 12:49AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/04/19 08:39AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Marc Friedman Marc Friedman 08/04/19 02:54PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Daniel '' Daniel '' 08/04/19 04:17PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Marc Friedman Marc Friedman 08/04/19 04:25PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/04/19 03:52PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/04/19 07:13PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Probably Fred Probably Fred 08/04/19 08:56PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 08/07/19 08:49AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/04/19 09:08PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Rebel Moby Rebel Moby 08/05/19 09:38AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jeff Parr Jeff Parr 08/06/19 02:51PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/07/19 08:21AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Mike Boyd Mike Boyd 08/07/19 12:37PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/07/19 06:26PM
