Re: Peugeot Vogue VS2 a Soft Seizure
Rebel Moby /
Plated bore so you can likely acid off the smeared aluminium and buff out the burnishing on the piston and throw on new rings. Give it a leak down test to see if you might have a vacuum leak in the casings.
