Re: Clutch removal on a jawa 210 problem
Blukas Lukas /
Yeah... i was already ready to replace the whole clutch as there was a problem with metal trying to do the work instead of rubber, i saw multiple videos on this, and i tried to pull it with a puller, which was working, but the inside was bending while the ouside was moving forward, then i tried to cut the welds that the thing was held in by, do you think i should straighten it out, and then heat it up, cause i think the rust has gone to the point that its welded on, i guess they forgot the assembly lube step in the factory.
