Intermittent spark .. express
Got a real nice 1980 Honda express,, thought I had no spark .. put tester in end of boot, and it lit up ! So I should have spark right? New plug ..no spark? Whaaaaat
Re: Intermittent spark .. express
Beach Club Nick /
You have the gap set correctly on both the plug and the tester? Would you happen to be using the wrong plug?
New plugs are not immune to being bad .
I would test coil resistance and reset point gap. Also gap the spark plug.
Always try the easiest thing first .
Test that tester a few times in the boot to make sure the result is not intermittent . Then test that new plug . Or , try a different new plug .
