Yes . HT coils do go bad . Not often , but , it does happen .
And , they don't have to be hot when it happens .
You might try removing the resistor from the plug cap and replace it with a piece of solid wire . Your system should be good with only a resistor plug or HT wire , as generally only 5K µ resistance is required .
