> Charles McCusker Wrote:
> Thanks for the reply, ya that's how I did it. Post to hook in the
> shortest geometry distance (when it's kicked up/back) is right at what
> looks to be 100mm. For whatever reason the ACE (my only stocked hardware
> store) had been picked over for springs. Best match I could find was a
> 3.5"x.5" OD spring. ALMOST works, just not enough compression when
> kicked up. They were out of 3.25"x.5" and 3"x.5" so time to drive
> further and see if anyone else has em.
> Point of thread was to see if anyone knew the Pacer spec one, and I'd
> just be lazy and order one off mcmaster.
Why not just cut the 'long' spring you have to the length you need ?
