Re: Puch Maxi - Stripped Engine Stud Inside the Engine Bottom
Adam Smith /
On my maxi I have a m6 helicoils in one of my intake bolts and one of my engine studs. They work well.
If you don’t have a drill press, and have to drill using a hand drill Have an assistant/friend watch to make sure you’re drilling straight. I’ve put helicoils in at angles before and it’s very annoying when you go to put it all back together and the threads won’t mesh (edited)
