Re: 1994 Tomos Targa LX no spark
♣Slew Foot♣ /
Is it a 3 or 4 hole case are there three or are there for pylons that amounts on the two lines on the case the bottom one is 4 no gasket and the Top Line is 4 if it has a thick gasket from the factory Now default just use a pencil or even better yet this is the easiest way to get the timing that will run put it to bottom dead center when it's there loosen the Poinsett so that it drops then tighten it now when it revolves and hits the lobe it will open at the proper time if your feel or foot isn't shot or if it's brand-new it might open too far in which case you put it to top dead center and drop a cigarette paper between the points and let him close when you loosen it and then tighten it again so that way it will just be closing at top dead center you can actually said it perfectly by mechanical means and just measuring from the top dead center of the piston with the head off measure 2 mm before top dead center and that's a default setting go a little bit hotter say 1.8 millimeters now even if the timing was totally whacked out it should fire get a 9 volt battery put the negative of it on the ground of the bike and run it across the high-tension coil signal in terminal without the wire on it you should get a big fat Spark if not did Static high-tension coil put a different one in the original the Chevy condenser should work it's just a capacitor if you ground the outside of it that is the negative all you do is put it in line it can be anywhere you can join all those wires that are on that Bolt and just put the condenser where the high-tension coil grounds to the frame and run the ground through itg
  1994 Tomos Targa LX no sparkTopic by: BBD 83 BBD 83 07/25/19 12:37AM
  Re: 1994 Tomos Targa LX no sparkRe: Don Ohio Don Ohio 07/25/19 12:42AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/25/19 12:43AM
  Re: 1994 Tomos Targa LX no sparkRe: Don Ohio Don Ohio 07/25/19 12:54AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/25/19 12:57AM
  Re: 1994 Tomos Targa LX no sparkRe: Don Ohio Don Ohio 07/25/19 01:09AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/25/19 01:59AM
  Re: 1994 Tomos Targa LX no sparkRe: Saabsonettguy . Saabsonettguy . 07/25/19 08:33AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/25/19 02:56PM
  Re: 1994 Tomos Targa LX no sparkRe: pat splat pat splat 07/25/19 03:22PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/25/19 03:24PM
  Re: 1994 Tomos Targa LX no sparkRe: Saabsonettguy . Saabsonettguy . 07/25/19 05:52PM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/27/19 09:54AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/27/19 11:17AM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/28/19 07:12AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/31/19 12:49AM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/31/19 01:43AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/31/19 01:47AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/01/19 02:33PM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/03/19 06:27AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/15/19 10:02AM
  Re: 1994 Tomos Targa LX no sparkRe: Buddy Shirey Buddy Shirey 08/15/19 11:49AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/15/19 09:59PM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/17/19 01:14PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/17/19 03:18PM
  Re: 1994 Tomos Targa LX no sparkRe: P D P D 08/18/19 08:14AM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/18/19 10:30PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/21/19 12:49PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/24/19 08:51PM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/24/19 08:57PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/25/19 01:19AM
  Re: 1994 Tomos Targa LX no sparkRe: Saabsonettguy . Saabsonettguy . 07/27/19 02:28PM
  Re: 1994 Tomos Targa LX no sparkRe: Saabsonettguy . Saabsonettguy . 08/04/19 11:57AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/04/19 12:11PM
  Re: 1994 Tomos Targa LX no sparkRe: P D P D 08/04/19 12:19PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/04/19 12:21PM
  Re: 1994 Tomos Targa LX no sparkRe: pat splat pat splat 08/25/19 08:28AM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/25/19 01:28PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/25/19 04:20PM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/25/19 04:33PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/26/19 08:28PM
  Re: 1994 Tomos Targa LX no sparkRe: Saabsonettguy . Saabsonettguy . 08/25/19 04:25PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/26/19 08:26PM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/26/19 11:21PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/27/19 12:56AM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/27/19 01:45AM
  Re: 1994 Tomos Targa LX no sparkRe: P D P D 08/27/19 08:53AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/27/19 09:07PM
  Re: 1994 Tomos Targa LX no sparkRe: Saabsonettguy . Saabsonettguy . 08/26/19 08:55PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/26/19 10:39PM
  Re: 1994 Tomos Targa LX no sparkRe: Saabsonettguy . Saabsonettguy . 08/27/19 08:22AM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/28/19 02:36AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/28/19 11:40PM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/29/19 01:27AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/29/19 11:32PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 09/03/19 03:54PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 09/06/19 11:27PM
  Re:Re: BBD 83 BBD 83 09/06/19 11:28PM
  Re: Re:Re: BBD 83 BBD 83 09/06/19 11:47PM
