Re: 1994 Tomos Targa LX no spark
Saabsonettguy . /
Brown is ground, green is the brake light and gray is the tail light. It doesn't affect the spark on this bike though. Basically all you need for spark is to connect the black stator wire to the positive side of the ignition coil, ground the body of the coil to the engine or chassis. Ground the body of the spark plug some bare metal on the engine or chassis. If you don't have spark this way your issue is likely in the points or condenser. Coils can go bad, but they're not usually the problem. I'll usually slip some fine emery paper or a points file through the window in the flywheel and clean the surface of the points, then follow up with a bit of rubbing alcohol on a piece of card paper to clean them up afterwards. Once the paper comes out clean you're good to go. If you do have to pull the flywheel to replace the points or condenser use the correct threaded puller. It'll cost you just under twenty bucks, but it's cheaper than replacing a flywheel that got mangled by a jaw type puller.
  1994 Tomos Targa LX no sparkTopic by: BBD 83 BBD 83 07/25/19 12:37AM
  Re: 1994 Tomos Targa LX no sparkRe: Don Ohio Don Ohio 07/25/19 12:42AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/25/19 12:43AM
  Re: 1994 Tomos Targa LX no sparkRe: Don Ohio Don Ohio 07/25/19 12:54AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/25/19 12:57AM
  Re: 1994 Tomos Targa LX no sparkRe: Don Ohio Don Ohio 07/25/19 01:09AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/25/19 01:59AM
  Re: 1994 Tomos Targa LX no sparkRe: Saabsonettguy . Saabsonettguy . 07/25/19 08:33AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/25/19 02:56PM
  Re: 1994 Tomos Targa LX no sparkRe: pat splat pat splat 07/25/19 03:22PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/25/19 03:24PM
  Re: 1994 Tomos Targa LX no sparkRe: Saabsonettguy . Saabsonettguy . 07/25/19 05:52PM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/27/19 09:54AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/27/19 11:17AM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/28/19 07:12AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/31/19 12:49AM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/31/19 01:43AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 07/31/19 01:47AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/01/19 02:33PM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/03/19 06:27AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/15/19 10:02AM
  Re: 1994 Tomos Targa LX no sparkRe: Buddy Shirey Buddy Shirey 08/15/19 11:49AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/15/19 09:59PM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/17/19 01:14PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/17/19 03:18PM
  Re: 1994 Tomos Targa LX no sparkRe: P D P D 08/18/19 08:14AM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/18/19 10:30PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/21/19 12:49PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/24/19 08:51PM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/24/19 08:57PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/25/19 01:19AM
  Re: 1994 Tomos Targa LX no sparkRe: Saabsonettguy . Saabsonettguy . 07/27/19 02:28PM
  Re: 1994 Tomos Targa LX no sparkRe: Saabsonettguy . Saabsonettguy . 08/04/19 11:57AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/04/19 12:11PM
  Re: 1994 Tomos Targa LX no sparkRe: P D P D 08/04/19 12:19PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/04/19 12:21PM
  Re: 1994 Tomos Targa LX no sparkRe: pat splat pat splat 08/25/19 08:28AM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/25/19 01:28PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/25/19 04:20PM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/25/19 04:33PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/26/19 08:28PM
  Re: 1994 Tomos Targa LX no sparkRe: Saabsonettguy . Saabsonettguy . 08/25/19 04:25PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/26/19 08:26PM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/26/19 11:21PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/27/19 12:56AM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/27/19 01:45AM
  Re: 1994 Tomos Targa LX no sparkRe: P D P D 08/27/19 08:53AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/27/19 09:07PM
  Re: 1994 Tomos Targa LX no sparkRe: Saabsonettguy . Saabsonettguy . 08/26/19 08:55PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/26/19 10:39PM
  Re: 1994 Tomos Targa LX no sparkRe: Saabsonettguy . Saabsonettguy . 08/27/19 08:22AM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/28/19 02:36AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/28/19 11:40PM
  Re: 1994 Tomos Targa LX no sparkRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/29/19 01:27AM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 08/29/19 11:32PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 09/03/19 03:54PM
  Re: 1994 Tomos Targa LX no sparkRe: BBD 83 BBD 83 09/06/19 11:27PM
  Re:Re: BBD 83 BBD 83 09/06/19 11:28PM
  Re: Re:Re: BBD 83 BBD 83 09/06/19 11:47PM
