Wowzers okay you see where that little bracket is there's supposed to be a long ceramic resistor there but they might have switched it to a small one inside of your headlight bucket or on your wiring block if it has the blue black stripe use it put them both the ground the one from the Magneto and the one from the tail if the resistors in place everything should work if it doesn't you can get away with three and a half foot of copper wire rap together like I get out just bundle it all up and tuck it somewhere I got out my meter and that's how much wiring it takes because that's 6 ohms of resistance. After that I would move on to checking the points the feeler foot do you have any lighting at all or is it all out and does it start do you have spark at any time
