Here's a couple shitty pics, you can see black coming from motor straight to coil and the yellow taped, the coil just has the plug wire coming off it. Pulled the flywheel cover to check points, you can see its the Iskra and seemed to have only 1 point to clean. It opens and closes but barely, not sure how much they open and close but we cleaned it up and still no spark at all.
