Re: Clank sound in midrange throttle position V1
Sean Daugherty /
Yeah, this makes sense. Since the only two things that have changed are the carb & exhaust. I currently have an air leak where the intake and carb meet. I'm sure that's not helping the situation & when it knocks it's always around half throttle.
Just so we are on the same page, it sounds like it's lean in the mid-throttle position causing the knock. WOT is good because the slide is all the way open.
Upjetting and/or adjust the slide cutaway should allow everything to be richer.
The Sha slide I have now has the slight angle towards the end. I think that makes it go slightly leaner from idle? Do you think I order a slide with the flat bottom? I also have seen people put a couple notches in towards the bottom of the angle. Any experience with that?
I have a shim, o-ring & 60 range jets on the way.
  Clank sound in midrange throttle position V1Topic by: Sean Daugherty Sean Daugherty 07/24/19 04:23PM
  Re: Clank sound in midrange throttle position V1Re: live ɘvil live ɘvil 07/24/19 09:27PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/24/19 09:45PM
  Re: Clank sound in midrange throttle position V1Re: Probably Fred Probably Fred 07/26/19 01:40PM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/24/19 11:38PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/25/19 08:55AM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/26/19 12:28PM
  Re: Clank sound in midrange throttle position V1Re: ♣Slew Foot♣ ♣Slew Foot♣ 07/28/19 07:22AM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/28/19 02:24PM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/28/19 11:55PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/29/19 09:00AM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/29/19 01:34PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/29/19 02:02PM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/29/19 02:10PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/29/19 03:24PM
  Re: Clank sound in midrange throttle position V1Re: Daniel '' Daniel '' 07/29/19 04:59PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/29/19 06:38PM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/29/19 05:30PM
  Re: Clank sound in midrange throttle position V1Re: Daniel '' Daniel '' 07/29/19 06:43PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/30/19 09:05AM
  Re: Clank sound in midrange throttle position V1Re: Daniel '' Daniel '' 08/01/19 01:14AM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 08/01/19 09:10AM
