Re: Clank sound in midrange throttle position V1
Daniel '' /
You shouldn't be pre igniting unless you have the compression real high, but I doubt you could even start it. Try a cooler heat range plug and maybe upjet a bit. You can maybe try messing with thw different slide cutaways too, seems like more of a carb tuning thing than an ignition if it is directly relatwd to a certain throttle position and not an rpm.
  Clank sound in midrange throttle position V1Topic by: Sean Daugherty Sean Daugherty 07/24/19 04:23PM
  Re: Clank sound in midrange throttle position V1Re: live ɘvil live ɘvil 07/24/19 09:27PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/24/19 09:45PM
  Re: Clank sound in midrange throttle position V1Re: Probably Fred Probably Fred 07/26/19 01:40PM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/24/19 11:38PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/25/19 08:55AM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/26/19 12:28PM
  Re: Clank sound in midrange throttle position V1Re: ♣Slew Foot♣ ♣Slew Foot♣ 07/28/19 07:22AM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/28/19 02:24PM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/28/19 11:55PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/29/19 09:00AM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/29/19 01:34PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/29/19 02:02PM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/29/19 02:10PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/29/19 03:24PM
  Re: Clank sound in midrange throttle position V1Re: Daniel '' Daniel '' 07/29/19 04:59PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/29/19 06:38PM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/29/19 05:30PM
  Re: Clank sound in midrange throttle position V1Re: Daniel '' Daniel '' 07/29/19 06:43PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/30/19 09:05AM
  Re: Clank sound in midrange throttle position V1Re: Daniel '' Daniel '' 08/01/19 01:14AM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 08/01/19 09:10AM
