Re: Clank sound in midrange throttle position V1
Probably Fred /
> Sean Daugherty Wrote:
> Point gap is about .016. The timing is adjusted to what the paper work
> said with the kit. I think it's like 22mm btdc. I never lubed anything
> in the flywheel. What does that entail? Same with points cam cleaning...
> thank you!
That is a must
The points ride on a cam on inside of flywheel just like valves or lifters ride on the cam in a car that must be free of rust and lubed, the pad need to be turned over/ cleaned then oiled
If you don’t service the magneto you will wear out your fiber points follower real quick, the points will close causing retarded timing and loss of spark and you’ll go slower and slower until there’s no spark, Or in extreme cases just sparkless right then and there,
It’s the first thing I ever do to a bike is remove the flywheel and service check everything out, I also inspect what I will say seal and crank end for rus/leakages
This is a puch ignition but all points ignitions are pretty much the same
If you can read my phone finger writings
  Clank sound in midrange throttle position V1Topic by: Sean Daugherty Sean Daugherty 07/24/19 04:23PM
  Re: Clank sound in midrange throttle position V1Re: live ɘvil live ɘvil 07/24/19 09:27PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/24/19 09:45PM
  Re: Clank sound in midrange throttle position V1Re: Probably Fred Probably Fred 07/26/19 01:40PM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/24/19 11:38PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/25/19 08:55AM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/26/19 12:28PM
  Re: Clank sound in midrange throttle position V1Re: ♣Slew Foot♣ ♣Slew Foot♣ 07/28/19 07:22AM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/28/19 02:24PM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/28/19 11:55PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/29/19 09:00AM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/29/19 01:34PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/29/19 02:02PM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/29/19 02:10PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/29/19 03:24PM
  Re: Clank sound in midrange throttle position V1Re: Daniel '' Daniel '' 07/29/19 04:59PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/29/19 06:38PM
  Re: Clank sound in midrange throttle position V1Re: Don Ohio Don Ohio 07/29/19 05:30PM
  Re: Clank sound in midrange throttle position V1Re: Daniel '' Daniel '' 07/29/19 06:43PM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 07/30/19 09:05AM
  Re: Clank sound in midrange throttle position V1Re: Daniel '' Daniel '' 08/01/19 01:14AM
  Re: Clank sound in midrange throttle position V1Re: Sean Daugherty Sean Daugherty 08/01/19 09:10AM
