Re: 1980 Express NC50 cleaned carb and now throttle cable does not work
Beach Club Nick /
> Mike Kirn Wrote:
> Is the throttle slide 180° off?
Yeah this is what's happening. There's a little nub inside the carburetor where the throttle slide goes. If you take the throttle cable/slide assembly out of the carb you'll see a slit on the cylindrical slide that the cable rests in that goes the whole way up the slide. That slit has to line up with the nub that's high up in the carb or else the slide/cable will never go down all the way.
