kinetic 2003 moped w/ a fuel delivery problem
Jesus G. saldivar /
Can anyone know what is going on with my original sha carb 12 10? The carb was cleaned already twice and i have good spark but still wont turn on, not even throwing starter fluid in the plug hole. The moped is hard to pedal, meaning it has good compression. I removed the spark plug several times and is dry? What you guys think it is, to all ciao and kinetic users? Thanks for responding!!!.
Re: kinetic 2003 moped w/ a fuel delivery problem
Bad crank seal or cylinder base gasket?
Sounds like gas not getting TO carb. Should've fired on starting fluid even if crank seals are bad. Replace that spark plug with new anyway.
Anthony Sanchez /
Remove the jet and make sure it’s clean and not clogged.
