Re: Drill test voltage?
Rocco Taco /
> Jimmy John Wrote:
> Got the engine mounted and pedaled the bike. Made sure to hook a
> multimeter up to the wire that feeds the ignition pack, and with great
> delight can report that the meter was reading 6v.
> Lesson learned is that rpms are correlated to voltage output. My drill
> could only spin the flywheel fast enough to generate 1v. When pedaling
> the bike, the flywheel spins fast enough to produce 6v.
> I’m confident I’ll have a big fat blue spark when I hook up my ignition
> pack and new plug!
Yea the same thing happens with the Treats CDI and it’s an absolute bitch to find where it’s firing with a drill and a timing light. I can get it to barley spark with the drill wide-open and because the timing advances with Rpm the timing is retarted when using a drill.
When you think something is broken but it’s actually just being tested wrong.
