Re: Drill test voltage?
> Jimmy John Wrote:
> Finally got some time to work on it again.
> Cleaned/ lightly sanded the points as suggested. Spun it up with the
> drill again... but still only reading 1v.
> Got pretty frustrated, and decided to hook up the ignition coil / spark
> plug to see what would happen. Spun it again, and lo and behold I have
> spark. It’s not a big fat blue spark, but it’ll jump the plug gap, and
> would also jump about a 1 inch gap from the end of the plug to the case.
> Planning on putting the engine back in the bike and seeing if it’ll
> start up with pedaling.
You need a good fat hot blue spark my friend especially on points. Cdis will not give you a big spark but it’s a fucking sharp one a will like make a snapping noise.
A lot of stuff can cause a bad spark. Bad points, bad primary or secondary coil, bad flywheel, bad wires or connections , bad spark plug wire and or boot, bad spark plug , bad ground
