Puch Magnum air filter
I have the stock air filter on my Puch Magnum and i'm looking for a replacement air filter element that goes inside. Does anyone know where to find the air filter that goes in the box?
airbox: https://www.sundaymorningmotors.com/product-p/c003018.htm
I have what's in the link but not the filter that goes inside.
I ordered the wrong part already and google is not helping. I'm open to changing it to a aftermarket filter at this point.
Re: Puch Magnum air filter
Probably Fred /
I use this one
https://www.treatland.tv/bing-air-filter-p/puch-bing-metal-hi-flow-filter.htm
but you will need have a performance pipe like this
https://www.treatland.tv/MLM-puch-magnum-techno-EDM-pipe-angle-port-p/mlm-pipe-magnum-401292.htm
Or mod/add a 5/16 hole way down inside your pipe and a same size hole hole in end cap
[attachment 202799 A63AF358-D49F-444A-A66F-F126A6B28809.jpeg]
You may need to up jet a few sizes to tune right but with that pipe and filter high 30s-40mph is obtainable
Maybe 33-35mph with modded stock pipe stock
Thanks! I'd like to keep things stock but it runs real lean without. If getting a replacement filter is not a option, I'd try this!
You looking for this? If so, email me at scuzz21@hotmail.com
Oh, maybe. It looks like what I already got and it's doesn't fit in the air box.
https://www.treatland.tv/replacement-metal-mesh-filter-for-17mm-bings-ONLY-p/17mm-bing-air-filter.htm
You probably have a Dellorto carb air filter/screen. It looks similar but it is actually different than the magnum air screen.
Possibly...the current carburetor is the OEM Bing, so it should need an air filter for the Bing. Are you referring to this carb?
https://www.treatland.tv/dellorto-SHA-15-15-carburetor-p/dellorto-sha-15.15-lever-puch.htm
It appears that only fits the 17mm Bing air filters, I’m guessing.
> air box.
Yeah. I pretty much knew it was the wrong part, but wishful thinking influenced adding it to the cart. For $14, I gave it a shot. If anyone wants to buy it, send a PM haha.
