any help would be appreciated in the install of the return spring under the starter clutch lever. The bottom of the spring only goes in one way but for the life of me I can't figure out how to get the other end in the hole in the clutch lever. see page 49 of Puch maxi manual. I have used an external spring that does the same thing so I can use moped, but I would rather have all original parts.
start clutch
Re: start clutch
Are you talking about how part 19 goes into 23 & 24?
Re: start clutch
Re: start clutch
Im having the same problem. Should #21 be able to pull out of the clutch cover without removing anything else? or do the clutch cover need to be removed?
