Hello! I just got a Oko blk blk 21mm and Polini jet, idle, and needle packs.
45 idle, JJn, 115
Stays running only with choke on. Yes (leak ?) So i took the motor apart again and put in new OEM crank seals, new gaskets and used 3M 600F oil/water resistant sealant on intake and base gasket area for extra sealing. Still wont idle without choke.
I put back my TM24 setup and idles and purrs like a kitten. Reason for getting the Oko is I'm going for a blacked out theme on the bike.
Are Oko's hard to get to idle? Maybe I got a bad carb? I wanted the stage 6 21mm but Treats was out. (edited)
