She likely soft seized the motor each time it quit . The tapping you hear is probably piston slap .
Best would be to replace the piston and rings . Cylinder condition would determine whether or not an oversize piston is needed .
Or , if the piston and cylinder are not too bad , just clean them up and run it . Live with the tap , tap ...
