Moped won't start
calvin williams /
I hit a fence and I unhooked a cable not sure where it goes moped will not start if anybody can help me out it would be greatly appreciate it I have attached a picture
Re: Moped won't start
Dirty30 Dillon /
Thou Hast a Scooter
Aaron Ward /
You have this all wrong. Take the one hose and put it where the other hose is. Then take the big red cable and switch it with the black cable. After that you will need to also remove all hose clamps and replace. Pro tip. If you cut that aqua color wire you will gain 10mph on your top end.
Cleats Onionpockets /
Y'all about to give me heartburn.
Calvin, you have a scooter (which some states classify as a moped, I know). The plumbing on your bike is more complicated than the basic mopeds on this site, which have pedals and drum brakes. You're not likely to get any helpful info here, but you WILL get lots of trolling.
Do you know which cable you hooked? You picture shows the carb, but which one do you think might have been snagged? In any case, you might have more luck on a dedicated scooter forum like this one
49cc Scoot.com
calvin williams /
Thanks everyone for your post but I still have not figured this out I'm not exactly sure where this cable came from I just know that it is unhooked and is keeping me from starting again I am attaching another picture of it and my moped
Find one of those donation boxes and just leave that shit there.
Just guessing here but I see a cable retainer clip just laying on the plastic housing and a hole in what appears to be the air intake, Maybe something broke when you crashed and dropped into the intake? Also go back to the scene of the incident and look around for parts laying on the ground.
If you're gonna come on a moped website asking for help then at least mention that its a Chinese scooter you have. There is a difference and not knowing that here is considered disrespectful. Just saying.
@Calvin,
That hose you're holding up is the drain line from the carb. Unless gas is actively pouring out of it, that's not what's preventing your bike from starting. You need the big three to make it work. Spark, fuel, compression. Make sure you have all three, and if the bike isn't running by that point, consider taking it to a local shop, or doing a fair amount of research on a dedicated scooter forum.
Bad Cadillac™ /
TROLLS!!!!!!!!!
Id sell it asap before the whole scooter cracks in half.
its a vip man
yep. thats the carberator float bowl over flow. not a big deal. just let in hang man. it does not need to be hooked up. pm me if you got and Q's on this bike. ive fixed quite a few GY6 scooters before i caught the vintage moped disease.
