Re: 1980 Peugeot 103SP 5 coil stator running lights at 13-20 volts!
Ryan . /
If you measured the voltage with all the bulbs blown and no regulator the. Of course your voltage is going to be through the roof. The system is balanced when the load of the correct number and type of bulbs draws down the output. VxA=W. If you are not drawing watts you are going to have excess voltage.
