Re: 1980 Peugeot 103SP 5 coil stator running lights at 13-20 volts!
Vermont Pete /
My tail light is running at the same high voltage and was blown. The speedometer, according to the wiring diagram, is on the same circuit and probably blown as well. It was hard to see in the daylight.
I don't suppose you have a link to the voltage regulator or ballast resistor?
Thanks!
-Pete
