Re: 1980 Peugeot 103SP 5 coil stator running lights at 13-20 volts!
jumpsuit steve /
hows your running light bulb?
i think the non air coil transformer harness runs the headlight, speedo, and tail on the same circuit? i have run a 10w as the tail, which dims the headlight due to the higher load on the circuit overall but keeps the nla sealed beams from blowing.
trailtech voltage regulator works, or just a ballast resistor / coil will work as a regulator.
