crankshaft assembly
is it possible to seperate the crankshaft pieces , can you take a few broken crankshafts and make one ?
Re: crankshaft assembly
All you need is patience, a arbor press and some hardwood V blocks to assist with alignment.
And at least one dial indicator
Probably Fred /
Run off gauge to check true alignment/run off, knowledge and experience to correct
