Re: Vespa SI won’t run right
Kristian Lomeland /
> Bad Cadillac™ Wrote:
> Put the original carb/jet back on and exhaust if it's not rusted out
> beyond use since those are the only two performance mods you've done to
> it. You can't tune it or do upgrades until you get it to run correctly.
> If you take the carb and pipe out of the mix and it runs right, then you
> know the issue is from one or both of those parts.
> If you take it back to all stock and it sill does not run right, then
> its an issue with something else you messed with.
> Here's my restored Si:
Thats the problem. I bought the moped in parts, with many parts rusted out or destroyed in other ways. Therefore no stock exhaust and a stock carb that leaks like hell.
I sort of have to figure it out with the lowboy exhaust and 13.13 carb.. -and i cant believe that neither of them are to blame.
But as I have "messed" with every nut and bolt, i am sure the problem is with something i’ve messed with.
I’ll try to fix this air leak in the crank case first, and then see whats what. Stock or not, that air leak is cooking up trouble. When the engine no longer reacts to the carb spray, we’ll see how she runs.
That is a super clean looking SI, man. Love the work. The Puch is also a looker!
  Vespa SI won’t run rightTopic by: Kristian Lomeland Kristian Lomeland 07/12/19 04:47PM
  Re: Vespa SI won’t run rightRe: Richard Eberline Richard Eberline 07/12/19 09:36PM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/13/19 01:56AM
  Re: Vespa SI won’t run rightRe: pat splat pat splat 07/13/19 12:45AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/14/19 04:12AM
  Re: Vespa SI won’t run rightRe: pat splat pat splat 07/14/19 01:15PM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/16/19 05:07PM
  Re: Vespa SI won’t run rightRe: pat splat pat splat 07/16/19 07:29PM
  Re: Vespa SI won’t run rightRe: live ɘvil live ɘvil 07/16/19 08:27PM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/17/19 03:15AM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/17/19 07:55AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/17/19 03:22PM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/18/19 06:47AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/18/19 06:37PM
  Re: Vespa SI won’t run rightRe: live ɘvil live ɘvil 08/16/19 03:36AM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/18/19 07:02AM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/18/19 07:11AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/19/19 06:30AM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/19/19 06:49AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/19/19 06:52AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/19/19 04:47PM
  Re: Vespa SI won’t run rightRe: Donald durkee Donald durkee 08/15/19 02:28PM
  Re: Vespa SI won’t run rightRe: live ɘvil live ɘvil 08/16/19 03:18AM
