Re: Vespa SI won’t run right
Kristian Lomeland /
> pat splat Wrote:
> dont use rtv, i always smear motoseal1 on both sides of the case gasket.
> and yes any air leak is gonna mess with your performance
Ok, so you use motoseal with the gasket. Always thought it was one or the other. Is it any danger of getting motoseal in to the engine, it i squeezes out a bit on the inside? I can get my hands on Permatex gasket sealer. Check the link:
https://www.permatex.com/products/gasketing/gasket-sealants/permatex-aviation-form-a-gasket-no-3-sealant-liquid/
Will this do the trick, or do i need motoseal1?
As the engine is installed back in the moped, i dont have a picture. But i drew the chip-size on the old case with a permanent marker to show you the size:
  Vespa SI won’t run rightTopic by: Kristian Lomeland Kristian Lomeland 07/12/19 04:47PM
  Re: Vespa SI won’t run rightRe: Richard Eberline Richard Eberline 07/12/19 09:36PM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/13/19 01:56AM
  Re: Vespa SI won’t run rightRe: pat splat pat splat 07/13/19 12:45AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/14/19 04:12AM
  Re: Vespa SI won’t run rightRe: pat splat pat splat 07/14/19 01:15PM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/16/19 05:07PM
  Re: Vespa SI won’t run rightRe: pat splat pat splat 07/16/19 07:29PM
  Re: Vespa SI won’t run rightRe: live ɘvil live ɘvil 07/16/19 08:27PM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/17/19 03:15AM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/17/19 07:55AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/17/19 03:22PM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/18/19 06:47AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/18/19 06:37PM
  Re: Vespa SI won’t run rightRe: live ɘvil live ɘvil 08/16/19 03:36AM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/18/19 07:02AM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/18/19 07:11AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/19/19 06:30AM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/19/19 06:49AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/19/19 06:52AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/19/19 04:47PM
  Re: Vespa SI won’t run rightRe: Donald durkee Donald durkee 08/15/19 02:28PM
  Re: Vespa SI won’t run rightRe: live ɘvil live ɘvil 08/16/19 03:18AM
