Re: Vespa SI won’t run right
Kristian Lomeland /
> Richard Eberline Wrote:
> Compression test PSI?
> .016 point gap
> plug NGK b5hs or b4h .019 gap
It did 115-125 psi in the comp test.
Yep, points set to .016 or 0.40mm in my world
Got a NGK B5hs with .019 gap
> pat splat Wrote:
> note; once u get it running perfect .you'll want to run that plastic air
> shroud that sits on top of the cylinder, its important for cooling n
> it'll seize.
Noted! Will look into getting hold of one, as mine didn’t have one when i got it!
Thanks to both of you for answers!(edited)
  Vespa SI won’t run rightTopic by: Kristian Lomeland Kristian Lomeland 07/12/19 04:47PM
  Re: Vespa SI won’t run rightRe: Richard Eberline Richard Eberline 07/12/19 09:36PM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/13/19 01:56AM
  Re: Vespa SI won’t run rightRe: pat splat pat splat 07/13/19 12:45AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/14/19 04:12AM
  Re: Vespa SI won’t run rightRe: pat splat pat splat 07/14/19 01:15PM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/16/19 05:07PM
  Re: Vespa SI won’t run rightRe: pat splat pat splat 07/16/19 07:29PM
  Re: Vespa SI won’t run rightRe: live ɘvil live ɘvil 07/16/19 08:27PM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/17/19 03:15AM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/17/19 07:55AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/17/19 03:22PM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/18/19 06:47AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/18/19 06:37PM
  Re: Vespa SI won’t run rightRe: live ɘvil live ɘvil 08/16/19 03:36AM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/18/19 07:02AM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/18/19 07:11AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/19/19 06:30AM
  Re: Vespa SI won’t run rightRe: Bad Cadillac™ Bad Cadillac™ 07/19/19 06:49AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/19/19 06:52AM
  Re: Vespa SI won’t run rightRe: Kristian Lomeland Kristian Lomeland 07/19/19 04:47PM
  Re: Vespa SI won’t run rightRe: Donald durkee Donald durkee 08/15/19 02:28PM
  Re: Vespa SI won’t run rightRe: live ɘvil live ɘvil 08/16/19 03:18AM
