Has an idle tuning circuit.
What's the other bolt under the mounting clamp?
I've ordered from aliexpress a few dozen times over the years without a single problem. (edited)
It says right in the title, it's a Bing carb for the IMT 506 agricultural tiller/tractor motor.
My guess is its an air bleed screw. Looks like there's a channel that runs to the venturi.
'Air' screws are generally ahead of the slide and fuel screws are behind the slide .
The mixture screw is on the intake manifold side of the slide. But the "other bolt" I mention is 180deg opposite it.
Eliminating other possibilities , that 'bolt' could have something to do with the primer circuit .
